If I have defined points for a route and then go and open the Find Route dialog, when I right click a stop, the focus leaves the find Route dialog and returns to ArcReader, so I cannot select anything in the pull right. So, I am unable to remove stops, or flash or anything for that matter. The behavior is seen not just with the pull right, but single clicking in the window, first gives focus to the Route dialog, and then it leaves for the Map window.
Repro:
Add Some stops.
Open Find Route dialog
select second stop
Stays selected for a second
Focus leaves for Map
Try and right click.
It appears for a millisecond, then disappears.
This may be a showstopper for those that use this tool, or you better be perfect when adding stops.
Its appearing that when the select focus leaves, the partial select in the window still can be removed via the remove button, so, not a showstopper, phewwww. I don't like being stuck on a release.
