I have a polygon feature class related to a table via Relationship Class (one-to-many, GlobalID in polygon related to a GUID in the table, field called REL_ZONE_ID). I am updating this related table manually. The related table lists the segments that intersect the polygons (polygon labels shown here are a shorthand version of the full Globals, full version listed in the REL_ZONE_ID field). So basically it's a table that keeps track of the lines intersecting a given polygon.
I am moving between Pro 3.1 and 3.2, so I can't yet reliably use "FeatureSetByRelationshipClass".
I would like to do this automatically with a Calculation Attribute Rule, at INSERT, UPDATE, and DELETE. My approach:
The below does this, but it's a hack--I needed to add in the if (editType != "DELETE") because otherwise when a polygon was deleted, the rule would remove the currently related records as expected, but then add the same records back in (except with a NULL related ID, since the polygon would have been deleted, and not have an ID anymore).
I thought I wouldn't need to do the if DELETE because I thought the "Intersect()" was being called on the $feature, and not the $originalFeature. So I assumed that if a feature was deleted, there couldn't be any intersections with the $feature, and therefore no records would be added to the "adds" array.
To reiterate, the code below does exactly what I want, I just can't do it without the special "DELETE" caveat.
/*MANAGE RELATED SEGMENTS*/
// INPUTS
var proVersion = 3.1
var editType = $editContext.editType
// Get original/current polygon feature.
var zone = $originalFeature
var newZone = $feature
// Get all polylines in SEGMENTS feature class. Geometry required for 'Intersects()'.
var segmentsFS = FeatureSetByName($datastore, "SEGMENT", ["SEG_ID"], true)
if (proVersion >= 3.2) {
// Get table records that are related to the current POLYGON feature.
var relRecordsFS = FeatureSetByRelationshipClass(zone, "ZONE_SEG_RELATION", ["*"], false)
} else {
// Get all records from the related table.
// Filter when related ID matches GlobalID of orignal POLYGON feature.
var relRecsFS = FeatureSetByName($datastore, "SEG_TBL", ["*"], false)
var zoneGlobalID = $originalFeature.GlobalID
var relRecordsFS = Filter(relRecsFS, 'REL_ZONE_ID = @zoneGlobalID')
// MAIN ------------------------------------------------------------------------------- #
// Iterate over the currently related table records, add all 'deletes' array.
var deletes = []
for (var relatedRecord in relRecordsFS) {
Console(`ALREADY RELATED / TO DELETE: ${relatedRecord.SEG_ID} | ${relatedRecord.GlobalID}`)
Push(deletes, {"globalID": relatedRecord.GlobalID})
// For every SEGMENT line, check if it intersects current ZONE. If so, add to 'adds' array.
var adds = []
if (editType != "DELETE") { // If a feature is deleted, there won't be anything getting added. "newZone" alone isn't working?
for (var seg in segmentsFS) {
if (Intersects(newZone, seg)) {
Console(`FOUND NEW INTERSECTION / TO ADD: ${seg.SEG_ID}`)
Push(adds, {"attributes": {"REL_ZONE_ID": newZone.GlobalID, "SEG_ID": seg.SEG_ID} })
Console(`\nDELETE RECORDS:\n${deletes}\n\nADD RECORDS:\n${adds}`)
return {
'edit': [{
'className': 'SEG_TBL', // This is the TABLE where the edits are occurring.
'deletes': deletes, // [{'globalID': XXX}, {'globalID': YYY}] <-- 2 delete examples
'adds': adds // [{"attributes": {"REL_ZONE_ID": newZone.GlobalID, "SEG_ID": seg.SEG_ID}}, {"attr...] <-- 2 adds
