Hello all, I have created a geodatabase for storm structures/pipes and want to have the pipes automatically calc some fields based on the points they are connected to. I have successfully written the attribute rules to do this and they work fine in arcgis pro. However, when I share them to arcgis as a feature layer and draw a pipe in the map viewer, the popup does not show the id calculated. I started to go down the road of pop-up configuration/attribute expressions, but isnt that what the AR is for? Also, the arcade expression in the AR doesnt work in the Attribute Expressions so i figured I am going about this all wrong. Help?
