When Multiple Child Records Exist, How to Carry Over Field Value of MOST RECENT Record to Parent Field
192
9
2 weeks ago
ChristopherBowering
Occasional Contributor II
Hello.  I currently have an Attribute Rule which carries over a desired value from a child field to a specified parent field (globalid to GUID, 1:M relationship class).  I didn't think about the fact that when multiple child records are associated to a single parent record I need to specify which child record's value will transfer over!
I have a date field in the child table (DATE_INSPECTION) and would like to be able to bring the most recent/current date value from said field (amongst multiple child records in a 1:M relationship) over to a parent field (DATE_LAST_INSPECTION). It also needs to function if there is only one related child record.  I'm not proficient enough in Arcade to figure this out.  Any date-related examples I've come across are too complex for me to finagle.  If someone (possibly @MikeMillerGIS coming in clutch for a second time today??) could help me out, I'd greatly appreciate it!  My current code is below.  Feel free to tweak it or provide something totally different that might work.
// Calculation Attribute Rule on Child
// Triggers: Insert, Update
// Field: empty
// do nothing if value did not change
if($originalfeature.CHILD_FIELD == $feature.CHILD_FIELD) { return null }
// get the feature
var TEST = First(FeatureSetByRelationshipName($feature, "OCGIS.DPW_TESTING_REL"))
if(TEST == null) { return null }
// Send a request to update the field in the parent FC
return {
  "edit": [
      "className": "PARENT_NAME",
      "updates": [
        {"globalID": TEST.GlobalID, "attributes": {"PARENT_FIELD": $feature.CHILD_FIELD}}
MikeMillerGIS
Esri Frequent Contributor
This one is a little harder, be easier to write if you can share a sample dataset.
The most performant, would be that we query the table the related record is using the foreign key to get the other records.  We then create a sort function by date to get the current date.  Then use that key or FSbyRelationship to get the parent record and update it if needed.
ChristopherBowering
Thanks for responding once again, I appreciate it!
The test datasets I've been using are incredibly simplistic.  If you create a point feature class with a GlobalID field and a date field and a table with a GUID field and a date field...using a GlobalID to GUID relationship class, that's the setup I'm using.  If there are 5 table records related to a single point, for example, each with a different date, I'd like the most current date to populate the parent date field (or the only existing date if there's only one record).
What you explain makes sense conceptually.
MikeMillerGIS
This should work.  If the parent features date is less than the edited child feature, update the parent.
Expects($feature, 'DATEFIELD');
if ($originalfeature.DATEFIELD == $feature.DATEFIELD) {
    return
var fs = FeatureSetByRelationshipName($feature, "RELNAME", ['DATEFIELD', 'GLOBALID'], false);
var parent_feat = First(fs);
if (IsEmpty(parent_feat)) {
    return;
if (parent_feat.DATEFIELD > $feature.DATEFIELD) {
    return
return {
    "edit": [
            "className": "PARENTFCNAME",
            "updates": [{
                "globalID": parent_feat.globalid,
                "attributes": {
                    "Size": $feature.DATEFIELD
ChristopherBowering
I will give this a try!  I assume the attribution rule is run on the child table with the field set to empty?  If it's not too much trouble, could you specify DATEFIELD_Parent or DATEFIELD_Child in your code?  Thank you!
MikeMillerGIS
Yes this rule would be assigned to the child table.  As for code changes, that is an exercise for the reader.
ChristopherBowering
I have been playing with this all morning and continue to get script errors on various lines regarding the Child field upon entering a date.
Here is how I've used your script (I've tried both with the attribute rule field empty and on the child field being used):
Parent Date Field: DATE_1
Child Date Field: DATE_INSPECTION
Expects($feature, 'DATE_INSPECTION');
if ($originalfeature.DATE_INSPECTION == $feature.DATE_INSPECTION) {
    return
var fs = FeatureSetByRelationshipName($feature, "OCGIS.DPW_TESTING_REL", ['DATE_1', 'GLOBALID'], false);
    return;
if (parent_feat.DATE_INSPECTION > $feature.DATE_1) {
    return
return {
    "edit": [
            "className": "OCGIS.DPW_TESTING",
            "updates": [{
                "attributes": {
                    "DATE_1": $feature.DATE_INSPECTION
The first script error message tells me the DATE_INSPECTION field can't be found on line 13.  If I swap out the parent for the child field on line 6 the error message then says the DATE_INSPECTION field can't be found on line 8 (which is odd because there isn't even a field present on that line).
I do appreciate your teaching technique mentioned in your last message but I am pretty new at this and am trying my best!  Thanks.
MikeMillerGIS
You are trying to access a row that not listed in the FeatureSet, make sure you list all the fields you need to use on the parent feature in the 3rd parameters
to
var fs = FeatureSetByRelationshipName($feature, "OCGIS.DPW_TESTING_REL", ['DATE_INSPECTION ', 'GLOBALID'], false);
But then you are mixing fields later on in the return statement.
What date fields are on the parent and what are on the child?
MikeMillerGIS
    return
    return;
if (parent_feat.DATE_1 > $feature.DATE_INSPECTION) {
    return
return {
    "edit": [
            "updates": [{
                "attributes": {
ChristopherBowering
This seems to be working now!  I assumed the Parent field would have to be facing the 'less than' side of the operator based on the conceptual description.  The remainder of the script I did have correct during one of my attempts but I didn't try switching around the operator on that line.  Thank you very much for your help with this scripting.
