Alert seems to conflict with entering the year on a Date Picker
377
04-13-2023 03:42 PM
CurtisWursten1
I'm new to Calcite and have been having trouble with entering a year in the Date Picker when I use an alert.  If an alert has been open, than the Date Picker year entry box doesn't seem to function properly.  Once the user selects a date after the incorrect year appears than the date picker works again.
Here is a codepen using the calcite sample with a datepicker and an alert.  Thank you and I appreciate any help on this.
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no" />
    <title>Calcite Components: Create a mapping app</title>
    <script src="https://js.arcgis.com/calcite-components/1.2.0/calcite.esm.js" type="module"></script>
    <link rel="stylesheet" href="https://js.arcgis.com/calcite-components/1.2.0/calcite.css" />
    <script src="https://js.arcgis.com/4.26/"></script>
    <link rel="stylesheet" href="https://js.arcgis.com/4.26/esri/themes/light/main.css" />
  </head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    body {
      display: flex;
    calcite-loader {
      align-self: center;
      justify-self: center;
    #header-title {
      margin-left: 1rem;
      margin-right: 1rem;
    #info-content {
      padding: 0.75rem;
    calcite-rating {
      margin-top: 0.25rem;
  </style>
 <body>
    <calcite-loader></calcite-loader>
    <calcite-shell content-behind hidden>
      <h2 id="header-title" slot="header">
        <!-- Dynamically populated -->
      </h2>
      <calcite-shell-panel slot="panel-start" detached>
        <calcite-action-bar slot="action-bar">
          <calcite-action data-action-id="information" icon="information" text="Information"></calcite-action>
        </calcite-action-bar>
        <!-- Map-specific panels (each one provides a div for a ArcGIS Maps SDK for JavaScript widget) -->
        <!-- Info panel (populates with info from the web map) -->
        <calcite-panel heading="Details" data-panel-id="information" hidden>
          <div id="info-content">
            <calcite-date-picker id="noRangePicker"></calcite-date-picker>
          </div>
        </calcite-panel>
      </calcite-shell-panel>
      <div id="viewDiv"></div>
    </calcite-shell>
                       <!--initial alert that provides liability info-->
       <calcite-alert kind="info" open icon auto-close auto-close-duration="fast" placement="bottom"
                   label="Info Liability" id="alert-info-liability">
            <div slot="message">
                This online parcel map is for reference only and no liability is
                assumed for any inaccuracies, incorrect data or variations from an actual survey.
            </div>
       </calcite-alert>
  </body>
  <script>
    require([
      "esri/WebMap",
      "esri/views/MapView",
    ], function(WebMap, MapView) {
      const webmapId = new URLSearchParams(window.location.search).get("webmap")
        ?? "210c5b77056846808c7a5ce93920be81";
      const map = new WebMap({
        portalItem: {
      const view = new MapView({
        map,
        container: "viewDiv",
        padding: {
          left: 49
      view.ui.move("zoom", "top-left");
      map.when(() => {
        const { title, description, thumbnailUrl, avgRating } = map.portalItem;
        document.querySelector("#header-title").textContent = title;
        let activeWidget;
        const handleActionBarClick = ({ target }) => {
          if (target.tagName !== "CALCITE-ACTION") {
            return;
          if (activeWidget) {
            document.querySelector(`[data-action-id=${activeWidget}]`).active = false;
            document.querySelector(`[data-panel-id=${activeWidget}]`).hidden = true;
          const nextWidget = target.dataset.actionId;
          if (nextWidget !== activeWidget) {
            document.querySelector(`[data-action-id=${nextWidget}]`).active = true;
            document.querySelector(`[data-panel-id=${nextWidget}]`).hidden = false;
            activeWidget = nextWidget;
          } else {
            activeWidget = null;
        document.querySelector("calcite-action-bar").addEventListener("click", handleActionBarClick);
        let actionBarExpanded = false;
        document.addEventListener("calciteActionBarToggle", event => {
          actionBarExpanded = !actionBarExpanded;
          view.padding = {
            left: actionBarExpanded ? 150 : 45
        document.querySelector("calcite-shell").hidden = false;
        document.querySelector("calcite-loader").hidden = true;
  </script>
</html>
KittyHurley
@CurtisWursten1 Thanks for reaching out - we've logged a bug to address the conflict in #6781.
KittyHurley
