I have a Map Document that exists on our Department's Network Drive that contains a lot of (<200) feature classes and layers. I wanted to work with one specific feature class and use it for a map I'm creating. So I save the layer as a layer file in my work machine. I then proceed to edit this file using ArcGIS to create new fields, delete existing ones, change symbology etc. I make some pretty heavy changes to the file and realize I screwed up by deleting a column I shouldn't have. Oh well, glad it's backed up in the Map Document.
I check the Map Document and go to the layer in question. The changes I made to the layer file I saved in my local machine were applied to the original layer. The columns were deleted in the original map doc.
How is this possible? How does saving the feature class as a separate layer file in my local machine not prevent this kind of screw up?
Thanks for the help. I really hope I haven't made permanent changes to the original layer, although it looks like that may be the case?
