Merge Divided Roads Tool issues
2202
06-12-2015 08:07 AM
JacobGuthrie
I am trying to make a road center line file using the Merge Divided Roads tool. However when I run the tool I get these results.
It does create a new Feature Class however it is empty. Does anyone know how to resolve this issue?
Thank you,
Jacob Guthrie
GIS Specialist
Tags (1)
DanPatterson_Retired
Sounds like you have some issues with the geometry of the input file, so run a Repair Geometry on it and it should remove null geometries.  Then run the MultiPartToSinglePart tool to explode your multipart features.  The repair geometry might fix the warnings about self-intersecting features, but they weren't the main problem... and you might want to try a simpler featureclass name ... like X ... until it works
