Route Events Not Updating
294
11-22-2019 10:37 AM
LaurenCombs
I have created a route events point field based on a table.
When using version 10.2 on a previous computer, the route events would update when the values in the table were changed.  You would change the value in the table then refresh the map view, and the point would update.
I am currently using version 10.6 and this is not happening.  I have tried closing Arcmap and opening again after table edits have been made, in addition to refreshing the view.  It seems the only way to reflect the updated data is to create a new route events layer.
Was this functionality removed from Arcmap at some point between 10.2 and 10.6?
