Cannot delete shortlist builder web map in My Content
1148
03-23-2017 10:23 AM
KimSapunar
New Contributor III
I have been testing the Shortlist Builder web mapping application.  I load up a .csv file into a webmap, then share as a Shortlist App, it creates the intermediary Mapname - Shortlist Builder.  This works fine.  However, it is just test data, and now I can't delete the files in My Content.   When I select the web map, the delete option is not available.
I created the data, it is in my account.  Any suggestions?
Tags (1)
JayHodny
Occasional Contributor III
Open the Shortlist Builder web map, click on the Settings tab, uncheck the Delete Protection box, then click on Save.  Return to your Content, and you should be able to select and delete the item.
JayHodny
KimSapunar
New Contributor III
Excellent, thank you.
JayHodny
You are very welcome.  I tripped over the same thing a few weeks ago.
