Hi! I am building a Crowdsourced Story Map. I've been working on it for about a month, now, but the settings tab (for Cover photo, Contributions, Header, etc) recently started having a pop-up message at the bottom:
I'm sorry for the trouble you're having. Can you share a little more information about how you're using the app, specifically if there were any changes before the story stopped being able to save?
I'm not sure exactly what is happening. It's possible if you added an invalid character or modified the app JSON through the AGO Assistant, it could have corrupted the data or become incompatible with something the app is reading. However, I tried duplicating you app in my account by copying the JSON data you used and I was still able to save the changes in my account. Are you able to reproduce this in a new crowdsource? If you start making changes, especially outside the builder can you verify the app save between each step.
Yes, you can add your old feature service to a new crowdsource app but will require editing the underlying JSON configuration through the AGO Assistant tool. Here are the steps:
Fig. 1
Fig. 2
