Story Maps-Disable Login Prompt
494
10-18-2017 04:21 AM
JamesFitzgerald3
New Contributor III
Hello, I downloaded the story map template from GitHub. Is there a way to disable the login prompt. I want my organization to be able to view the story map but not have to create a AGOL account.  The template is located on my server. Any help is appreciated!!
Tags (1)
RupertEssinger
Hi James
So in this case, the Story Map hosted in ArcGIS Online isn't/won't be shared publicly right? (If it is shared publicly, your users wouldn't need an ArcGIS Online account to view your story via your customized code).
Rupert
JamesFitzgerald3
New Contributor III
Rupert,
I have developed a web application where the user needs to see the story map. I have downloaded the story map from GitHub and placed the code on my server.  I cannot share it publicly. The user will not have a AGOL account. The user only accesses the story map through the web application I have created. I need to overwrite the login proxy to story map. I have read developers editing the config.JS file and index.html file by creating a proxy. Thanks
