Hi Scott,
We've identified the issue with the login screen as a bug that was introduced in last night's update. We are working on a fix that will be deployed tonight. I apologize for the trouble.
Regarding your other question about bookmarks and sections: I'm working on a GeoNet blog post on this, but that is expected due to a change we made in how sequential sections are implemented in this beta release. You can no longer have two sequential sections in a row. If you made a story like this in beta 1 or if you create this situation, for example by deleting or moving an immersive section, sequential sections will be combined.
In your case, you also lost a bookmark since the sequential section that had the bookmark was combined with a previous section when you opened builder for the first time after the update. I'd recommend inserting a title section to break up your story and you can add a new bookmark on the new title section or on the new sequential section following the title section. Sorry that this change has affected your story.
Owen
Owen Evans
