The share tool is used by Esri staff and Esri Community MVPs to duplicate a message to one or more boards of the same type. For example, posting a question regarding sharing a feature service from ArcGIS Pro to ArcGIS Enterprise, could be created on the ArcGIS Pro questions board and then shared to the ArcGIS Enterprise questions board to provide higher visibility of the question.
To share a message, use the following steps:
NOTE: When a post is shared, all copies of it remain connected so that comments, thread replies, and Accepted Solutions added to any of those copies will sync across the others so that users can build on the same conversation from multiple locations. Syncing occurs on a 24 hour cycle.
@EdCarter, are you seeing this page without any formatting, including no paragraphs, numbering, or images? We want to make sure we understand the block of copy-pasted text from the article to your comment, which doesn't reflect how this How To article is set up or what we're seeing on our end. Thanks for clarifying.
Thanks for clarifying that it's an Outlook email that you're referring to, @EdCarter. Though the image you tried to upload isn't displaying correctly, I can confirm that email notifications from Esri Community do not support most formatting. Instead, we recommend treating those emails more as awareness that there's been an update to a post, Board, or Place that you're subscribed to in Esri Community and visit it within our platform to view the new content as it's meant to be displayed. Hope this helps!
