GDBAdminPython2017.zip
2495
03-03-2017 03:45 PM
The presentation slides and demo code for the Administering your Enterprise Geodatabase using Python session at Developer's Summit, March 2017.
Comments
Thank you so much.
- mostafa
Thank you for the video here Administering your Enterprise Geodatabase using Python - YouTube .
I happened to be working and tweaking a maintenance script. If I may ask a few questions here ...
  • In the video, I saw the the sql account used by geodatabase admin by default had all the privileges - Select, Insert, Update, Delete. It does not seem to be what I see in the geodatabases I created. I follow this ESRI document (Privileges for geodatabases in SQL Server—Help | ArcGIS Desktop), and the sde account has following previleges - Create function, Create procedure, Create table, Create view, and View definition. However, sde only has Select privilege on all the tables and feature classes that users create. My questions are: First, should sde have all 4 privileges by default? Second, what additional privilege should I grand to the sde account to make 'that' by default?
  • Also, is there a tool that would list all the geodatabases (excluding non-geodatabases) on a given SQL instance?
Version history
Last update:
‎03-03-2017 03:45 PM
Updated by:
Contributors
