Change the Editor Options Dialog Version Tab choice "Edit a version of the database with the ability to undo and redo" to read "Edit non-versioned data"
This idea has been closed as a duplicate of the ArcGIS Pro Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
