Dave -
The fastest and easiest way to populate your subtype field is use "Select by Attributes" and select the records based on a particular attribute value. For example, Type = "Interstate". From there, use the Field Calculator and calculate the subtype field to the appropriate subtype code (i.e. Subtype_Field = 1) Do this workflow for the remaining 14 subtype codes. There are other ways to select features as well - manual approach and then use the Field Calculator.
Hope this helps!
Robert LeClair
Esri-Denver
Hi Karl,
Did you get help for this issue?
How did you select subtype field in field calculator anyway?
Thanks.
