Adding Elevation Data to Shapefile
4538
10-04-2012 11:44 AM
MattGillen
Hi there,
I apologize if this, or something similar, has been asked recently and if I'm not in the right forum for this issue.
I have a shapefile of every zip code in the United States. I have then broke it down by State and am focusing on New York right now. I want to import a DEM of New York and then take the centroid of each zip code and find the elevation. I'd like the elevation to then be an attribute within the zip code shapefile. I have the centroids as a lat/lon coordinate given int he zip code shapefile.
Currently, I do not have a DEM file on New York, and wanted to see if this was possible to due before trying to get one. If any of you have another idea on how to get the elevation of a centroid, please feel free to suggest it as I am open to different ways of doing this, as I will be needing to do this for 25-30 states.
Thank you so much for any help you can provide!
Matt
JonathanQuinn
Esri Notable Contributor
Do you have the Spatial Analyst extension?  You can use the Extract Values to Points tool within Spatial Analyst > Extraction  > Extract Values to Points.
