I re-created our address locators to look at our geodatabase data (as opposed to our shapefiles) but am running into an issue. The new locators were built in ArcGIS 10 and the previous ones looking at shapefiles were built in 9.3. When I use the new locators in ArcMap using the Find tool it is only returning candidates that match 100%, even checking on the "Show all candidates" checkbox. If I look for the same address using the older locator is lists other candidates as well. Or, if I try an address that doesn't exist, the old locators will list likely candidates but the new locators simply say "No objects found". I used the same matching parameters when I re-created the locators. Is this a known issue? Thank you!
