Analyze Feature Class using ArcGIS Pro
596
02-04-2023 04:23 PM
Labels (3)
yockee
Occasional Contributor II
I used to be able to run this geoprocessing using ArcMap 10.5 against Oracle 12 Database :
import arcpy
arcpy.AnalyzeDatasets_management("D:/path_to_connectionfile/dbspatial.sde",
"SYSTEM", ["xxx";"xxx"],"ANALYZE_BASE", "NO_ANALYZE_DELTA", "NO_ANALYZE_ARCHIVE")
Now the database has been upgraded to Oracle 19 and I can not connect to geodatabase anymore using ArcMap 10.6. The only way I can connect is by using ArcGIS Pro. But I am very unfamiliar with its layout. I want to do the geoprocessing above or may be there are any equivalent format to achieve the same thing.
I can connect to the geodatabase just fine but I just have not find a way to run that geoprocessing.
Need your help and advice
JayantaPoddar
MVP Esteemed Contributor
Oracle 19C is supported from ArcGIS 10.6.1 with ArcGIS (Desktop, Engine, Server) Support for Oracle 19c Patch .
Oracle database requirements for ArcGIS 10.6.x
Think Location
yockee
Hi, sorry I was wrong. It turns out that I have ArcMAP 10.5.
so, how do I run that piece of code on ArcGIS Pro ?
MarceloMarques
Analyze (Data Management)—ArcGIS Pro | Documentation
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
