ArcGIS Diagrammer 10.3
42239
35
12-11-2014 06:53 AM
MichaelGayheart1
Richie Carmichael
We utilize ArcGIS Diagrammer to maintain all of our GDB designs. After upgrading to 10.3, we can't open ArcGIS Diagrammer. An update supporting 10.3 would be greatly appreciated!
CharlesFried
Hi Marius:  You can find the 10.2.2 SDK download on my.esri.com (go to the "My Organization" tab, then Downloads) that install should have the required DLLs for Diagrammer.
DixieBooker-Lair__GISP
In order to get the ArcGIS Diagrammer 10.3 to work in a Windows 10 environment, ArcMap 10.5, using Microsoft Visio Professional 2013
Make the following modifications in Microsoft Visio Trust Center:
Open Microsoft Visio, Click the "File" tab.
Click "Options"
Click "Trust Center"
Click "Trust Center Settings"
Click "File Block Settings"
Uncheck the "Open" option for the following:
"Visio 2003-2010 Binary Drawings, Templates and Stencils"
"Visio 200 - 2002 Binary Drawings, Templates and Stencils"
"Visio 5.0 or earlier Binary Drawings, Templates and Stencils"
Click "OK" until you can close.
ArcGIS Geodatabase Diagrammer for 10X
http://www.arcgis.com/home/item.html?id=a378b48be11b45b5bb25254643304cb7
Follow the publish directions that you download with the tool.
Now run the Geodatabase Diagrammer for 10X from ArcCatalog (Version 10.5) (again).
Best Regards,
Dixie Booker-Lair, GISP
Asrujit_SenGupta
MVP Regular Contributor
Just to clarify something to avoid confusion, the ArcGIS Diagrammer and the Geodatabase Diagrammer are two different tools.
This thread was discussing about the ArcGIS Diagrammer, which was last released for ArcGIS 10.2.x.
ArcGIS Diagrammer
maherelayyan2
So this will work with ArcGIS 10.3 ?
but i need to do some updates to visio ?
maherelayyan2
Since Diagrammer work only with 10.2  so is X ray software give the same capabilities if i needed it with ArcGIS 10.3
for preparing diagram for GDB ?
ÁkosHalmai
Occasional Contributor II
It is still possible to run the ArcGIS Diagrammer, even with ArcGIS 10.6.:
  1. Just install the Diagrammer from the following link: https://www.arcgis.com/home/item.html?id=51b6066bfd024962999f6903682d8978
  2. Navigate to C:\Program Files (x86)\ArcGIS\Desktop10.6\bin and locate the ArcMap.exe.config file. Open it in Notepad or Notepad++ and copy the whole content.
  3. Navigate to C:\Program Files (x86)\ArcGIS Diagrammer\BIN and locate the ESRI.ArcGIS.ArcDiagrammer.exe.config file open it, and paste the content of the ArcMap.exe.config file. Save it. You probably need administrative privileges to do so.
  4. Go to C:\Windows\Microsoft.NET\assembly\GAC_MSIL\ESRI.ArcGIS.Geodatabase\v4.0_10.6.0.0__8fc3cc631e44ad86 and copy ESRI.ArcGIS.Geodatabase.dll and paste to C:\Program Files (x86)\ArcGIS Diagrammer\BIN. You probably need administrative privileges.
  5. Go to C:\Windows\Microsoft.NET\assembly\GAC_MSIL\ESRI.ArcGIS.System\v4.0_10.6.0.0__8fc3cc631e44ad86 and copy ESRI.ArcGIS.System.dll and paste to C:\Program Files (x86)\ArcGIS Diagrammer\BIN. You probably need administrative privileges.
  6. Voilà! Start C:\Program Files (x86)\ArcGIS Diagrammer\BIN\ESRI.ArcGIS.ArcDiagrammer.exe.
Warning! This is not a new version, still the old Diagrammer. Some new geoadatbase features, like editor tracking and new annotations from Pro are not supported. You can export the created xml and import into a new geodatabase, however you won’t be able to open a newly exported workspace document xml in the Diagrammer. So now it is a one way tool. The Diagrammer uses workspace document xml version 9.2, the 2.3 Pro uses 10.7. so there is no way going back. But it is still OK for me.
The paths may vary depending on your installations and ArcGIS version. The solution is not working with ArcGIS Pro, you need to have an ArcGIS for Desktop ArcMap installed.
This solution is not perfect just a workaround–use at your own risk.
Ákos Halmai
