Hello:
I installed and configured ArcGIS Server Standard 10.1 and ArcSDE 10.1 with Postgresql on RedHat 6. When I try to create an enterprise geodatase from ArcGIS Desktop I get the following error message:
Executing: CreateEnterpriseGeodatabase PostgreSQL 192.168.5.....
Start Time: Mon Aug 06 12:16:55 2012
User has privileges required to create database objects.
Geodatabase admin user already exists.
Database created.
Validated authorization file.
User has required privileges for geodatabase setup.
XML support is enabled for the database instance.
You must copy the latest ST_GEOMETRY and dependent libraries to the PostgreSQL software location. Refer to the ArcGIS help topics for more details.
Connected RDBMS instance is not setup for Esri spatial type configuration.
Failed to execute (CreateEnterpriseGeodatabase).
Failed at Mon Aug 06 12:17:00 2012 (Elapsed Time: 5.00 seconds)
I copied the st_geometry and other files from /opt/sdepg/sdeexe101/lib to /opt/Postgresql/9.0/lib, but the error remains
The same steps where executed on Windows 2008 server and there was no error
The error message doesn't give to much information about the cause of it and I really don't know what else I should do
I already have defined the environmental variables in .bashrc and .bash_profile from /home/sde
I tried to run sdesetup from commandline, but it is available only for rater data; it went smoothly with no problems at all
Any idea would help
Thank you,
Ionut
