we have versioned tables in arcsde sql server geodatabase (version 10 SP1 64 bit on SQL 2008). while registering as versioned we selected move edits to base option. it is working properly. after edit session system is moving edits to business tables and emptiying delta tables as required.
however if we have attachments enabled for same feature class, attachments wont be moved to business tables after edit session until we compress the database. So A and D delta tables of attachments are keeping records.
as far as i can see from table registry, object_flags are showing values of versioned layer without move edits to base option for attachments, although related layer holds move edits to base tables option.
is this behaviour expected, or is there a specific reason for that?
