I have a map with many polygon data, point data, line data and text created and edited using Auto CAD. Please guide me through to create this map in ArcGIS 10.
I have a bunch of lines that were drawn in AutoCAD and I need to turn them into polygons. The problem is there are overshoots and undershoots or varying lengths. What is the quickest way to fix this? I have an ArcInfo 9.2 license if that helps.
Hi ArifPK,
Can you give me more details as to what exactly you are trying to create? You might want to check CAD To Geodatabase tool.
