Automatically delete vertices on polygons, basing on the intersection with points
2062
06-27-2014 03:36 PM
PaoloPensalfini
New Contributor III
Hi all!
I need to automatically remove some vertices (about 10000) on multiple polygons.
I know the exact position of these vertices I want to delete in the polygons and I created a point feature class of them.
I need to know if I can delete those vertices using the points file.
I created a little buffer around those points and used the buffer as "erase" in the erase tool, as described here:
http://gis.stackexchange.com/questions/74716/how-to-identify-and-delete-duplicate-vertices
I tried different buffers according to the dataset 's xy resoution...
Unluckly it didn't work.
Please, could you suggest me a better solution?
Thanks in advance
Paolo
PaoloPensalfini
New Contributor III
I answer to myself!
Luckly Dan Iseminger from FME gave me an help.
Here attached is an FME workflow that solves my problem. I changed a little bit it inserting an "anchor snapper" transform to make the vertices coincide perfectly to the points and..... It works perfectly (ArcGIS 10.1)!!
Thanks again Dan!
Paolo
