I have a huge amount of .csv files each with hundreds of rows and each has its own value of an easting and northing
How can i quickly change these UTM coordinates and convert them to a lat/long coordinate value using ArcMap.
What might you suggest is the most efficient method? Im very new to this, so any help and details is greatly apprecaited
Nope... I live at latitude 45ish North our northing is in the 5,000,000ish range... you are further north, ergo your northing would be greater than mine since you are further north and the northing is measured from the equator as a reference point... so you eastings and northings surely are not UTM. They have been alter to some other base reference and/or they are in a different projection.
-114 0 0.00000 /* central meridian
42 0 0.00000 /* latitude of the origin
2500000.0000 /* false easting (meters)
1200000.0000 /* false northing (meters)
LOAD_PROJECTION PROJ_NAME="TM_NAD83"
with a little bit of diggiging i discovered it
So, did you find the correct projection? If not, you may be able to get to the right one by altering the UTM Zone 11 CRS properties (double-click UTM Zone 11 to get to properties). The scale parameter may be different, though.
Is one of your points here?
Yep, they used NAD83 TM (Meters), after finding the false easting i was able to locate the projection of TM
the other data sets had NAD83 UTM 11
Marina, no projection parameters?
See if you can copy them to this and see where it shows up. Just do a couple of them.
used it, BINGO............were in mexico again. oh my goodness!
I really like that tool too!
Who gave you those coordinates ? This is something you need to ask them where did these came from before your frustrated set in ?
Indeed Robert,
i worked on the other files and they matched up excellent in ArcMap, using the above methods; save to x,y extent, add fields, and finally convert to shapefile and calculate the geometry. I also know there is a batch file converter in arcmap, i haven't played with it yet. My goal is/was to make a data model in model builder of the process and let the engineers(people) convert their hearts out. Its not so easy!
