Can anyone assist with using the 'convert coordinate notation' tool?
1229
06-03-2017 06:11 PM
NicoleGallahar
I used the 'project' tool to project all layers in my map (ArcGIS v10.2) to the same coordinate system (UTM GDA 94 zone 56) to do a spatial join. However, the coordinates remain the same in the attribute table (I understand that this is normal). However, I need to export all the coordinates in UTM GDA 94 zone 56 to an excel file. I had thought I could use the tool 'Convert coordinate notation' to convert the points and then do an excel export to accomplish this, but I have not had success with the 'Convert coordinate notation' tool. Is anyone able to assist?
Thank you very much.
DanPatterson_Retired
Just calculate the coordinates in planar units using http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/add-xy-coordinates.htm
there is no need using the convert coordinate notation... project the data, then add the coordinates in projected units.
NicoleGallahar
Thank you very much Dan. Much appreciated.
MirHashmi
Hi, If it solved your issue better to select it as an answer so that it will be useful to others. Thanks.
