Can't create address locator in 10
1526
01-25-2011 04:40 AM
DanPrice
Cannot Create address locator
I am trying to create an address locator that I had created in versions before 10. First, I tried rebuilding my original address locator from 9.3.1 & ArcToolbox crashed.  I deleted it & just tried to create a new one in ArcToolbox 10, but it will not.  Now Im up the creek with out a geocoder.
I am using a "US Address - Single house" style.  I need to do address searches & geocode addresses based on dbf created by my organization
My reference data is a point shapefile for my address points & Im using it as a primary table. The data looks like this for example:
Example: 255 N Cimmaron Rd W
Where:
255 = House Number
N = Prefix direction
Cimmaron = Street Name
Rd = Suffix Type
W = Suffix Direction
This is how it looks as far as data fields are titled:
255 = House Number = STNUM
N = Prefix direction = STDIR
Cimmaron = Street Name = STNAME
Rd = Suffix Type = STTYPE
W = Suffix Direction = STSUFFIX
I do not need CITY or ZIP or STATE as I am in a place that is within one city name, Zip, & state.
This is how I would go about creating address locators in previous ArcToolbox versions & always had success.
When I try, it wont work & the box pops up to send an error report.
Here is the python error msg:
arcpyCreateAddressLocator_geocoding("US Address - Single House","//Volgis/gis/Basemap/address_points.shp 'Primary Table'","'Feature ID' FID VISIBLE NONE;'*House Number' STNUM VISIBLE NONE;'Prefix Direction' STPREFIX VISIBLE NONE;'Prefix Type' <None> VISIBLE NONE;'*Street Name' STNAME VISIBLE NONE;'Suffix Type' STTYPE VISIBLE NONE;'Suffix Direction' STSUFFIX VISIBLE NONE;'City or Place' <None> VISIBLE NONE;'ZIP Code' <None> VISIBLE NONE;State <None> VISIBLE NONE;'Additional Field' <None> VISIBLE NONE;'Altname JoinID' <None> VISIBLE NONE","//Volgis/gis/Basemap/address_points_CreateAddress")
Im not sure what's going on but I need to resolve this because no users can search for addresses.  I tried creating it in with different names & different file locations with no luck.  I know it's has to be something simple.
Thanks in advance!
DanPrice
Dan you Dumba$$
You re-created your address points shapfile to contain a unit number field.
For instance, you have 18 points for 1089 W Jackson St with units 1 thru 18 on each point.  That is why when you tried to create address locator, it failed.  DOY!
You're lucky you have your handsomeness & a nice chick cos you're a GIS iditard, and your baseball team sucks.
DublinOhio
New Contributor III
It's awesome when you can solve your own problems.
It's even more awesome when you entertain all of us.
Thanks for a bright spot in the day!
