Hi all,
I am trying to change my DB (sde single, 9.3.1) collation, but some dependencies exist:
Msg 5075, Level 16, State 1, Line 1
The object 'spatial_ref_zunits' is dependent on database collation. The database collation cannot be changed if a schema-bound object depends on it. Remove the dependencies on the database collation and then retry the operation.
The object 'spatial_ref_xyunits' is dependent on database collation. The database collation cannot be changed if a schema-bound object depends on it. Remove the dependencies on the database collation and then retry the operation.
Msg 5072, Level 16, State 1, Line 1
ALTER DATABASE failed. The default collation of database 'static' cannot be set to SQL_Latin1_General_CP1_CI_AS.
Has anyone handled this before?
TIA
Hen
