Hi All,
I am having one way replication enabled towards the site. We were faced few hick ups in synchronisation and now all sorted out and the synch working fine for the last two weeks. The issue currently have is the compress is not clearing the delta tables which is happening after each synch.
select id,name from sde.gdb_replicas;
ID NAME
6 IO_ANT
11 IOENVIRON
In that 11 IOENVIRON is working ok. IO_ANT is having heaps version still exist. I have queried to check whether any orphan version exist that preventing from clearing the delta tables. There are no orphan version exist
SQL> select name from versions order by name;
05_07_10
AB_Nov_VMI
AF_Edits
Agha_edit
DD_Edits
DEFAULT
SYNC_SEND_11_93
SYNC_SEND_6_29
SYNC_SEND_6_30
SYNC_SEND_6_31
SYNC_SEND_6_32
SYNC_SEND_6_33
SYNC_SEND_6_34
SYNC_SEND_6_35
SYNC_SEND_6_36
SYNC_SEND_6_37
SYNC_SEND_6_38
SYNC_SEND_6_39
SYNC_SEND_6_40
SYNC_SEND_6_41
SYNC_SEND_6_42
SYNC_SEND_6_43
SYNC_SEND_6_44
SYNC_SEND_6_45
SYNC_SEND_6_46
SYNC_SEND_6_47
SYNC_SEND_6_48
SYNC_SEND_6_49
SYNC_SEND_6_50
SYNC_SEND_6_51
SYNC_SEND_6_52
SYNC_SEND_6_53
SYNC_SEND_6_54
SYNC_SEND_6_55
SYNC_SEND_6_56
SYNC_SEND_6_57
SYNC_SEND_6_58
SYNC_SEND_6_59
SYNC_SEND_6_60
SYNC_SEND_6_61
SYNC_SEND_6_62
SYNC_SEND_6_63
SYNC_SEND_6_64
SYNC_SEND_6_65
SYNC_SEND_6_66
SYNC_SEND_6_67
SYNC_SEND_6_68
SYNC_SEND_6_69
SYNC_SEND_6_70
SYNC_SEND_6_71
SYNC_SEND_6_72
SYNC_SEND_6_73
SYNC_SEND_6_29 - if you look above query the issue starting from this version onwards this version date is two months ago which I doubt created when we were facing synch failiure, from here onwards it is keeping all versions till today. Which accumulating the delta layers.
SYNC_SEND_6_73 is todays version and 73 is the replica state.
Is there any way to get rid of the version staring from SYNC_SEND_6_29 to SYNC_SEND_6_72 so that I can perform a compress and get cleared my delta tables. At the moment I am facing serious performance issuses while rendering the layers.
Your help is really appreciated
Cheers
Antony
