Converting DEM elevation range into a polygon
12303
11-10-2012 05:06 PM
JoshuaBenton
New Contributor III
I need to be able to convert an elevation range in a DEM into a polygon and I am having a heck of a time figuring out how to use the reclass tool. I am not sure how to create the remap table! Is anyone know of how to make this happen?
JakeSkinner
Esri Esteemed Contributor
Hi Joshua,
You can accomplish this using the Reclassify tool in Spatial or 3D Analyst toolbox.  Open the tool, select your DEM for the input, and then click 'Classify'.  Set the classes to 3 and click OK.  Specify one of the 'Old Values' range to your desired elevation range that you want the polygon to be.  For example, if your DEM has values from 1.5 - 58.7, and you're interested in values 20-30, then you should specify the Old Values to be in ranges:
0 - 19.9
20.0 - 30.0
30.1 - 58.7
The new values would default to 1, 2, and 3.  After your new raster is created, you can open the attribute table and select Values = 2.  Next run the Raster to Polygon tool on the selection and you will have your new polygon.
JakeSkinner
Hi Joshua,
0 - 19.9
20.0 - 30.0
30.1 - 58.7
JoshuaBenton
New Contributor III
Hi Joshua,
0 - 19.9
20.0 - 30.0
30.1 - 58.7
Thank you for your reply! I figured it our doing the same thing and I also learned that there is a big difference between the Reclassify and Reclass tools as well.
