Dear experds,
What is the relation between Coordinate System and spatial Data Type ?
I creates some FCs :
1. Coordinate System : Projected, Config Keyword : Geography. Result: Failed. SQL Native Client 11.0: The multi-part identifier "SHAPE.STSrid" could not be bound"
2. Coordinate : Projected, Keyword : Geometry. Result ; Success
3. Coordinate : Geography, Keyword : Geography. Result ; Success
4. Coordinate : Geography, Keyword : Geometry. Result ; Success
What factor are causing the error ? Which spatial data type should I choose for Projected and Geography coordinate system ?
[SQL Server 2012. Arcgis 10.1]
thanks
Hi Haniu,
For each of the spatial data type there may be an appropriate coordinate systems to use. Here is a link to the information ArcGIS and Microsoft Spatial types
Usually using the Geometry option is suggested for projected data.
For the Geography option:
From the help -
"You might use the geography storage type with ArcGIS if
Hopefully this helps.
-George
Hi Haniu,
From the help -
-George
Allright George.. thanks.
