DBMS table not found (-37) when setup sde
2784
06-23-2011 07:24 AM
zhangyx
setup sde error
Upgrading geodatabase schema:
Error: DBMS table not found (-37).
       Error upgrading GDB schema.
Geodatabase schema object install not completed.
-sh-3.2$
my environment is:
CentOS Linux 5.4 + Oracle 11.1.0.6.0 + SDE for oracle11g
VinceAngelo
Esri Esteemed Contributor
What version of ArcSDE exists in the database?
What version of ArcSDE are you trying to install?
Are there tables which have been registered with either ArcSDE or the geodatabase,
but then deleted by a means which would not delete orphaned metadata records?
- V
