DBMS table not found (-37)
8623
12
09-04-2012 01:33 AM
AntonGonak
When I trying to create a view with the following syntax:
sdetable -o create_view -T DPSTR_GIS.CONS_SHP_LAND_V -t DPSTR_GIS.CONS_SHP_LAND,DPSTR_GIS.CONS_LAND -c DPSTR_GIS.CONS_SHP_LAND.OBJECTID,DPSTR_GIS.CONS_SHP_LAND.SHAPE,DPSTR_GIS.CONS_SHP_LAND.NSI_ID,DPSTR_GIS.CONS_LAND.CAD_NUM,DPSTR_GIS.CONS_LAND.ALLOW_USE,DPSTR_GIS.CONS_LAND.LAND_CAT,DPSTR_GIS.CONS_LAND.DEN_AREA,DPSTR_GIS.CONS_LAND.LOCATION_O,DPSTR_GIS.CONS_LAND.TYPE_LAW,DPSTR_GIS.CONS_LAND.TYPE_RIGHT -w "DPSTR_GIS.CONS_SHP_LAND.NSI_ID = DPSTR_GIS.CONS_LAND.NSI_ID" -i 5151 -s arcinfo.sibsac -u dpstr_gis -p dpstr_g
The below generates the following error:
ArcSDE 9.2  for Oracle10g Build 775 Fri Sep 17 10:45:27  2010
Attribute        Administration Utility
        Error: DBMS table not found (-37).
Error: Unable to create view DPSTR_GIS.CONS_SHP_LAND_V
But if I convert the script to the query it is executed without error. Example:
Select
from DPSTR_GIS.CONS_SHP_LAND,DPSTR_GIS.CONS_LAND
where DPSTR_GIS.CONS_SHP_LAND.NSI_ID = DPSTR_GIS.CONS_LAND.NSI_ID;
JuhoVainio
sdelayer -o register doesn't work in this case because the view doesn't have a spatial column. From the docs: "Registers with ArcSDE a table having a spatial column".
VinceAngelo
Esri Esteemed Contributor
If the view doesn't have a spatial column then there isn't any need to use any ArcSDE command-line utilities on it for any reason.  'sdetable -o create_view' exists exclusively for the creation of spatial views against layers with SDEBINARY/SDELOB geometry storage.  All other views should be constructed using database tools (or database tool wrappers, like Create Database View (Data Management)‌).  Spatial views constructed with SQL against ST_GEOMETRY or native geometry columns must be registered with ArcSDE before they can be used from ArcGIS for Desktop as simple feature classes (as opposed to Query Layers, which do not require registration).  Views cannot be registered with the geodatabases as full feature classes because that requires an SDE-set registered rowid column, and views can only have USER-set rowids.
- V
JuhoVainio
If I don't register the view using the sdetable command, then I cannot publish the view in the ArcGIS server and query the data using the ObjectID column. Now that I've "tricked" the SDE into believing that my view is an SDE table, I can successfully query the data from the view using ArcGIS server.
