Delete Records of Delta Table (A&D)
3162
10
06-14-2017 02:36 AM
PhuNguyen
New Contributor III
Hello,
Can i delete records of Delta table (A & D) in SQL Enterprise Geodatabase using SQL?
Thanks.
Asrujit_SenGupta
MVP Regular Contributor
I believe that you shared the results from the Diagnose tools. You can take a full DB backup and then execute the Repair tool. Repair Version Tables—Help | ArcGIS Desktop
However, I'll recommend that if you are not completely sure, contact Esri Tech Support and they can guide you on a call and a quick screen sharing session.
Asrujit_SenGupta
No. You should not play with the Tables in a Geodatabase from the database end. Inconsistencies may occur later.
Maybe you can share the issue, which is leading you to delete the records from the Delta tables and can find a solution for that here.
PhuNguyen
New Contributor III
I used the Compress Geoprocessing Tool to compress a geodatabase but sde compress didn't empty delta table.
PhuNguyen
New Contributor III
And I can't Full Compress because I can't delete version tree in enterprise geodatabase. It relate to my replication geodatabase, map services and feature services when I published.
Asrujit_SenGupta
Partial Compress is not an issue.
You can do the Full Compress later sometime by deciding upon a convenient downtime for that geodatabase. take a look at this link:
Acheiving Full Compress on Geodatabases with Existing Replicas | Support Services Blog
PhuNguyen
New Contributor III
I used Partial Compress but not work. This is version diagnose:
74309 rows referencing nonexistent states found in PHUWAGISV1.SDE.a73 (PHUWAGISV1.SDE.FCDONGHOKHACHHANG)
74309 rows referencing nonexistent states found in PHUWAGISV1.SDE.d73 (PHUWAGISV1.SDE.FCDONGHOKHACHHANG)
Diagnose Tables: 99 multiversioned tables examined,
1 multiversioned tables had orphaned, duplicate, missing or redundant rows.
Can you help me next steps?
Asrujit_SenGupta
PhuNguyen
New Contributor III
Thanks Asrujit SenGupta.
I'll try.
PhuNguyen
New Contributor III
I have solved this problem.
I used Repair Version Tables tool.
Thanks.
Asrujit_SenGupta
Great! Close the thread if your question has been answered by marking the appropriate response as "Mark Correct"
