Hi Guru,I'm using ArcSde 10 running on Oracle 10g at linux machine.My problem is when want to bring up the sde service, the error appear
ArcSDE 10.0 for Oracle10g Build 685 Fri May 14 12:05:43 2010
ST_Geometry Schema Owner: (SDE) Type Release: 1007
Instance initialized for ((sde)) . . .
Connected to instance . . .
Insufficient access to /tmp
WARNING: SDETMP: Setting temp path to /tmp
DBMS Connection established...
ERROR: Cannot Initialize Shared Memory (-79)
Delete /oracle-staging/sde10/sdeexe100/tmp/esri_sde and /oracle-staging/sde10/sdeexe100/tmp/esri_sde.lock if present.
Could not start ArcSDE -- Check Network, $SDEHOME disk, DBMS settings and dbinit.sde.
I check at /oracle-staging/sde10/sdeexe100/tmp folder, no files there..Oracle is up and running.Please help meThanks
