ERROR installing ArcSDE 10 Ora 11G- XML -create Index
776
07-23-2011 03:48 PM
Arturo_FranciscoAcosta_Bazán
I have a BD ORACLE 11G and AGServer 10 in windows server 2008 R2 .
I used the setup option for creating the repository manually changing the parameters of dbtune,
for it had created  user "sde" and tablespace "sde"  and "sde_movegdba" and for versioning
In the dbtune only change the parameters to DATADICTIONARY
dbtune.sde :
##DATA_DICTIONARY
ATTRIBUTE_BINARY  "BLOB"
B_STORAGE               "PCTFREE 0 INITRANS 4
                         TABLESPACE sde
                         STORAGE (INITIAL 40K)"
B_INDEX_ROWID           "PCTFREE 0 INITRANS 4
                         TABLESPACE sde
                         STORAGE (INITIAL 40K) NOLOGGING"
B_INDEX_USER            "PCTFREE 0 INITRANS 4
                         TABLESPACE sde
STATES_TABLE            "INITRANS 4
                         TABLESPACE sde_movegdba
                         STORAGE (INITIAL 1M)"
STATES_INDEX            "INITRANS 5
                         STORAGE (INITIAL 128K) NOLOGGING"
STATE_LINEAGES_TABLE    "PCTFREE 0 INITRANS 4
                         STORAGE (INITIAL 7M)"
STATE_LINEAGES_INDEX    "PCTFREE 0 INITRANS 4
                           STORAGE (INITIAL 5M) NOLOGGING"
VERSIONS_TABLE          "INITRANS 4
                         STORAGE (INITIAL 256K)"
VERSIONS_INDEX          "INITRANS 4
MVTABLES_MODIFIED_TABLE "INITRANS 4
                         STORAGE (INITIAL 2M)"
MVTABLES_MODIFIED_INDEX "INITRANS 4
                         STORAGE (INITIAL  2M) NOLOGGING"
XML_INDEX_TAGS_TABLE    "INITRANS 4
                         TABLESPACE sde
XML_INDEX_TAGS_INDEX    "INITRANS 5
                         TABLESPACE sde
END
But try I get the message
VERSION table created...
SPATIAL_REFERENCES table being created...
SPATIAL_REFERENCES table created...
GEOMETRY_COLUMNS table being created...
GEOMETRY_COLUMNS table created...
LAYERS table being created...
LAYERS table created...
METADATA table being created...
METADATA table created...
RASTER_COLUMNS table being created...
RASTER_COLUMNS table created...
TABLE_REGISTRY table being created...
TABLE_REGISTRY table created...
COLUMN_REGISTRY table being created...
COLUMN_REGISTRY table created...
STATES table being created...
STATES table created...
VERSIONS table being created...
VERSIONS table created...
MVTABLES_MODIFIED table being created...
MVTABLES_MODIFIED table created...
STATE_LINEAGES table being created...
S_instance_add_lineage_id_index:Error creating index (2158)Error: << ORA-02158: opción CREATE INDEX no válida
DB_instance_lineages_table_exists:Error creating STATE_LINEAGE(lineage_id) index (2158)
ERROR in creating STATE_LINEAGES table.
Error: 2158
DBMS error code: 2158
SDE schema object install not completed.
ERROR installing/upgrading ArcSDE, Error = -1
It is an error in reading the xml oracle or bad is that I have set the parameters of DBTUNE ????
VinceAngelo
Esri Esteemed Contributor
The main problem with editing the dbtune.sde file before initial setup is the possibility of
corrupting the file so that you can't install.   Try dropping the SDE user and starting over
with an original DBTUNE file.  If setup fails again, then your Oracle instance doesn't have
the correct configuration for XML support; if it doesn't fail, pay closer attention to the
changes you are making to the initial dbtune.sde.
- V
The mistake is that the configuration of dbtune use WORDPAD  when it should have opened the file with NOTEPAD. Now it works, this error is incredible !!
