Is there any way to export my GIS polygon layer to CAD with a color fill? I can only get it to export as a polyline boundary.
Hi Nina,
Sorry, it is not possible to export GIS Polygon layer to CAD with a color fill. Alternatively, you can have the boundaries in different colors.
If you just add a field to the polygon layer called "Color" and then use Export to CAD, you will get polygons but with desired boundary colors. Some standard AutoCAD color numbers are as follows: 1 = Red 2 = Yellow 3 = Green 4 = Cyan 5 = Blue 6 = Magenta 7 = White
