Using ArcGIS Pro 2.4.1
I have an aerial image as a Tif file that I have Georeferenced with manually placed control points.
If I use the option "Save", then it just creates external files being *.tfwx and *.tif.aux.xml
Other mapping applications aren't able to read these and render the image in the right location.
So then I used the "Save as New" which creates a new raster file with the georeferencing information.
This saves a new file but the result is a lot paler and washed out than my original image.
I have tried JPG, JP2, TIF, PNG and it occurs with all.
Maybe it is something to do with other options in the Export raster dialog. I am just accepting defaults pretty much. eg. 8 bit unsigned, Cell Size etc.
There is no documentation that really assists with choosing the right values.
Any suggestions ?
