Dunno what version you're using but here is a script to count the characters in a field. If that doesn't work here is a workaround.Make another field for latitude that only allows two decimals. Populate it with field calculator Left([Fieldname],...). Now make another field and subtract the two-digit values from the latitude field. Any result that comes back 0 will mean the original latitude also only had two decimals (unless the last 4 digits were all zeroes in which case the latitude field won't show them, but the odds of that happening are very small). Repeat for longitude.
