I am trying to geocode 58,000+ addresses which only contain city and state, no address. After a few hundred I am getting an error returned that says "There was an error trying to process this table." It does not always happen at the same point. Any suggestions for troubleshooting?
I am getting the same issue, most of the times it bombs out around the 40K mark. I am not hitting the file size limit and I have scrubbed the data to ensure there are no bad values. Any suggestions? I need to add around 1.4M addresses for my current project.
I'd suggest to both of you to split out your files and geocode the subsets; if things bail out then and all the time, it's a memory issue or something not data related. However, if you can geocode a couple of subsets and others bail, it points to the data.
With all due respect, 1.4 million records is a lot of records for one bad one to hide in and so is 58k for that matter....
Hope this helps-
