Geodatabase Toolset GDBT for ArcGIS 10 : User Information crashes ArcCatalog
1088
8
11-17-2010 02:31 PM
MarkChilcott
Occasional Contributor III
Downloaded the GDBT extension from :
http://www.esri.com/apps/products/download/index.cfm?fuseaction=download.all
(Noted the download was not mentioned on the www.esri.com web site for extensions)
When I select the User Information, it crashes ArcCatalog.
ArcGIS 10 Service Pack 1
ArcSDE 9.3 (Oracle)
HelenYang
Hi, Mark,
Where did you get the User information button?
I installed from the GDBT10.zip. But I have only "Edit Information, Versionaing lineage, spatial index info and version information" button at GDBT tab.
ArcGIS 10
ArcSDE 9.3.1 Sp2 Oracle 11.2
VinceAngelo
Esri Esteemed Contributor
Mark -
If the "User Information" tab is returns the same information that 'sdetable -o list_grantees' does
(using  SE_table_get_grantee_privilege_list) against 10.0 servers, then it's trying to use a capability
that does not exist in pre-10.0 servers (see #NIM062845).
- V
JohnMeza
New Contributor III
Sorry for the confusion.
The problem this thread (and another) refer to may be due to the following:
This version of the Geodatabase Toolset for ArcCatalog 10.0 was accidentally placed on the external webiste.
The Geodatabase Toolset for ArcCatalog 10.0 uses the following controls:
-Microsoft Common Dialog Control (comdlg32.ocx)
-Microsoft Chart Control (mschr20.ocx)
-Microsoft FlexGrid Control (msflxgrd.ocx)
-Microsoft Tabbed Dialog Control (tabctl32.ocx)
These are controls that have been commonly available with VB 6 and in older Windows OS' (ie. XP).
But in Win7, Windows 2008, etc. those controls are not found in the newer OS'.
We would like to include those controls in the install, but that requires review of licensing agreements. We are actively working on the licensing agreements but that is taking a long time.
In the meantime, while the controls listed may be found on the web and  installed independently of GDBT for ArcCatalog 10.0, this has potential licensing problems.  We are trying to work out these issues.
An install with the controls embedded will be available soon.
thanks
John
TedCronin
MVP Honored Contributor
This is good news.  I thought they weren't releasing a new GDBT.  Seems like this should be a download on the Resource Site.
How would you find this path, there is a lot of stuff here?  Perhaps a lot that can be removed.
AnthonySchaffer
New Contributor III
It's been a month since the last post on this subject.  Could someone from ESRI reply to let us know the status of the GDBT for ArcGIS 10?
NateArnold
Bump - this is a handy tool, would like a 10 version.
MoizIshfaq
Hello everyone,
Could anyone share information on where can I download the GDBT for ArcGIS 10? I know it might have licensing issues as is mentioned in this thread but I would see if I can handle it.
Thanks.
DerekLaw
FYI,
The GDBT for ArcGIS 10 is now available for download:
Hope this helps,
