Currently using ArcGIS Desktop 10.5.1.
Need to import (or export if easier) various shapefiles to a newly created File Geodatabase.
Have tried several options but same results or errors / warnings. Warning 000594 and such.
It will import and create a file but it is only a few of the points in the original shapefile.
For example, my Area_Drain shapefile has 1040 points but only imports 40. And my Catch_Basin shapefile has 5054 points but only imports 248.
Any help figuring this out is appreciated!!!!
