I have recently migrated some water main data from AutoCAD into a SDE Feature Class. Everything seems to have gone fine with that but now when I add this water main FC into ArcMap and hit the Zoom to Full Extent button, it zooms "way out". I have checked and there aren't any outlying features that would cause this. I have also checked in the Data Frame Properties -> Data Frame tab -> Extent used by Full Extent Command and when I set this to the water mains layer, it still zooms "way out". FYI, my ArcMap session, has only the water mains layer in it, no other layers were added and or deleted before I added the water mains layer (in other words, it was a fresh/clean session).
I am using ArcGIS 10.2 with Enterprise SDE (on SQL Server 2012).
Does anyone know how to update this feature class so it won't zoom "way out" when I hit the Zoom to Full Extent button?
I've thought about updating the spatial index but I'm not sure if that will do the trick (I don't think it will).
Thank you for your time,
Matt S.
