How many rows will an attribute table hold??
1720
02-21-2014 08:04 AM
MoniqueDawson
I am exporting tables in arc so that I can import as a dbase table to perform a joint to point files. However some data gets lost. How many rows will an attribute table hold??
ScottMoyer
In a filegeodatabase, the maximum number of rows in a feature class or table: 4,294,967,295 (ArcHelp 10.0). In older versions of Excel the number was 64,376, if I remember correctly. If you're meeting the latter number you may want to try using Access.
Scott
ScottMoyer
Interesting that 10.2 help says for maximum rows in a file geodatabase: "Number of rows in a feature class or table: 2,147,483,647". This is exactly half of what 10.0 help stated.
http://resources.arcgis.com/en/help/main/10.2/index.html#//018s00000002000000
Scott
