How to create spatial index for Aerial Photos
3784
30
08-20-2016 08:36 AM
JessiecarEsguerra
New Contributor III
Hi Guys, I need help in building a spatial index of Aerial photos and have the Image Service project on the fly. Appreciate any ideas or inputs from anyone who has knowledge about this.
Thanks in advance.
- Jessiecar
NeilAyres
But, how do you know where in the raster image (pixel position, row & col) these control points are located?
JessiecarEsguerra
New Contributor III
The Aerial photo's filename is also included on the metadata.
Using the filename, I could identify what are the control points for each from the metadata.
XanderBakker
Esri Esteemed Contributor
Can you attach an example of the Metadata for an aerial photo? Just to know what your possibilities will be...
JessiecarEsguerra
New Contributor III
Sure Xander.
See attached screenshot containing a sample metadata for an Aerial photo. I tried attaching an excel file but I can't here.
XanderBakker
The corner correspond to the fiducial marks? Are these always in the same location (row, column in the digital image)?
NeilAyres
I very much doubt it. These are photos later scanned to get them into an image file.
The pixel coordinates will depend on the position through the scanner.
I very much doubt there will be any correlation between pictures as to the exact pixel locations of fiducial marks.
However, you do seem to have the picture centre in Lat/Long. Perhaps something could be engineered out of that.
XanderBakker
I have my doubts too, but with some numpy executed on corner rectangles with a certain extent, i think these marks can be identified and can be tied together with the metadata. Would be interesting to try this...
NeilAyres
It will be very interesting to see you try. Good luck
XanderBakker
Thanks Neil, I'm sure I can use all the luck I can get. Probably the scikit-image: Image processing in Python — scikit-image  could be very helpful.
JessiecarEsguerra
New Contributor III
Thanks everyone for all your input and feedback.
We have actually tried a few photos and it was georeferenced on the right location though there's a slight misalignment which I think is expected since these are Historical photos.
