How to edit graph properties such as font size
464
12-29-2012 09:48 AM
Tamsen_TremainByfield
I am using ArcInfo v10, Desktop. I've created and added a graph to my map layout. I've right-clicked on the map, gone to "Properties" and....cannot find any way to:
1) change graph legend or title font size
2) remove graph legend border
3) change order of legend labels: currently the legend has the patch symbol, then the value of the graphed field, then a label from another column. I would like to put the column label before the numerical value and add text.
Is this type of graph editing possible in v10.0? There is no "Advanced Properties" option anywhere.
If I must do these tasks manually, how do I do this?
Thank you.
Apologies,
Just found the solution. A bit hidden!
Kind regards
