How to nonversion a single feature class within a feature dataset in SDE?
400
08-10-2017 10:17 AM
AaronThompson
New Contributor III
Hi all,
I have a feature class that was added later to a feature dataset within my organizations SDE database. For some odd reason, it came in as a versioned feature class, even though all the other feature classes/feature dataset are not registered as versioned. How can I change that one outlier feature class to nonversioned without having to version the entire dataset and then nonversion it again?
Thanks!
Asrujit_SenGupta
MVP Regular Contributor
Check if you can drag and drop the FC outside the dataset > Unregister it as Versioned > Add it back inside the Dataset
