How to re-assign 'select' after FME drops a table?
773
06-24-2014 12:19 PM
MatthewBaker2
Occasional Contributor II
Hi all,
To update our Production 10.1 SDE I give my DBA a model that he has to enter his username and password into, then when he runs it, it runs any number of FME ETL tools from within the Toolbox that I have configured and will load the data as needed, with parameters exposed for the username and password the DBA will enter.
The problem I'm having is when we 'drop' a table because there is a schema-change, FME re-creates it and loads the data, but the re-created table is invisible to the 'GIS-read' user until the DBA re-assigns 'select' privileges via ArcCatalog.
The process of re-assigning the 'select' privileges is what we want to replace with an automated process that I can configure in the model the DBA runs with the FME tools.
Is there a geoprocessing tool that will do what the 'privileges' GUI in ArcCatalog does?
Any thoughts appreciated!
Thanks!
-m
