Hi ,
I am working on ArcGIS 9.3.1 Data Interoperablity Tools. I need to import the Microstation Design file(*.dgn) by programically. I did it by Geoprocessing tool by opening the "Data Interoperatblity tools.tbx". It imports the dgn file into fgdb but when i open feature layer in ArcMap, it shows a warning message (Inconsistent extent). I checked the log file generated by ArcCatalog-> DataInteroperablity Tools-> QuickImport and my code both. I got a difference in these two. In Catalog log file it uses a MASTER coordinate units whereas with my code it uses the SUB coordinate units. If it do the same by using ArcCatalog with SUB coordinate units, it shows the warning message in ArcMap.
How can i change this settings by code. I tried so much but no luck still. Code is as below :
pToolWorkspaceFactory = New ESRI.ArcGIS.Geoprocessing.ToolboxWorkspaceFactory
pToolWorkspace = pToolWorkspaceFactory.OpenFromFile("C:\Program Files\ArcGIS\ArcToolbox\Toolboxes", 0)
If (pToolWorkspace IsNot Nothing) Then
pGPToolbox = pToolWorkspace.OpenToolbox("Data Interoperability Tools")
If (pGPToolbox IsNot Nothing) Then
pGPTool = pGPToolbox.OpenTool("QuickImport")
If (pGPTool IsNot Nothing) Then
pParams = pGPTool.ParameterInfo
pParameter = pParams.Element(0) 'First Parameter (Microstation DGN File)
pParamEdit = pParameter
pDataType = pParameter.DataType
sValue = "IGDS," + strDgnFilePath
pParamEdit.Value = pDataType.CreateValue(sValue)
pParameter = pParams.Element(1) 'Second Parameter (Ouput FGDB Path)
sValue = strFGDBPath
pTrackCancel = New ESRI.ArcGIS.Display.CancelTracker
pGPComHelper = New GpDispatch
pEnvMgr = pGPComHelper.EnvironmentManager
pMess = pGPTool.Validate(pParams, False, Nothing)
If CheckForError(pMess) = True Then
Dim isValidTool As Boolean = pGPTool.IsValid()
pGPTool.Execute(pParams, pTrackCancel, pEnvMgr, pMess)
IsImported = True
Else
IsImported = False
End If
End If
End If
End if
Please help me.
Can i do the same in another way?
Thanks in advance.
Sharad arya
