Import XYZ tiles from local path
1494
02-10-2022 11:47 PM
Labels (2)
AdrianPatrulescu
New Contributor III
Hi
It is possible to import XYZ Tiles from local path into ArcGis Pro project
I have a xyz tile grouped by zoom levels and I want to import them into ArcGis Pro project
I was trying add data from path command but seems not working with xyz tiles
file:///D:/Lucru/FCC/GIS/Date/VectoriZonaFCC/ZonaFCC/Tile/{z}/{x}/{y}.png
but not showing anything. The tile service layer was created but seems to be empty.
I was trying the same command in QGIS and the tiles was importing
Thank you
Adrian
MarinaBernhard
same problem here. And I tried the ASCII to Feature Class tool. Doesn't work with ArcGIS Pro, works with ArcMaps and QGis.
If I tried it with Pro  the folder with xyz files are shown empty.
What's the problem?
Why?
